You are right. Your 60' and ET aren't bad but with that 1/8 trap speed, your ET should be more like 7.5-7.6.
The Saleen is more nose heavy than a GT so you could try removing the front swaybar to aid weight transfer to the rear. You could also do some weight reduction in general, including lighter wheels. I'm sure others will chime in with further suggestions.
