This happen to anyone else? My AC is only blowing cold in the passenger side. I do NOT have dual zone climate control.
Any ideas?
Any ideas?
Yes....pita.Aw crap. Do I need to pull the entire dash out to get to that?
Well the air that is coming out isn'taas cold as it should be, so I'm thinking low refrigerant or plugged evaporator or condenser. But that's an interesting nteresting idea; where is that module located?Have the car checked for hvac codes from the Smart Junction Box. Have you tried the Cold Boot procedure? http://iihs.net/fsm/?d=332&f=Climate Control System.pdf&p=2
Best to make sure it's an actuator problem first before tearing into the dash removal for a broken door.
