Joe88xj
I have 2 questions...So I found a really good deal on a canton aluminum 4 quart hi capacity supercharger coolant expansion tank. I would be installing this in my 06 GT with a dob manifold and m122 blower on a stock 3v engine so 450 whp will be my cap for now. I wouldn't even be looking at this tank because its prob more tank than I really need but its priced really right. I figure more volume of coolant in the system would give better cooling and I found a good deal on an afco double pass heat exchanger too so cooler is better right?
So I am reading up on this canton tank and on lethal's website they state the tank is for drag racing only. I am not planning on drag racing the car its my weekend evening cruise toy, g to understand what it is about this tank that maybe road trips to beach or NYC so it would be driven for extended time periods. What is it about this tank that makes it only for drag racing? Should I pass on this tank and get one not for drag racing only? I am trying to figure out why its for drag racing only, I hate to pass up on a good deal on something like this. Sorry if the question sounds dumb.
https://www.lethalperformance.com/c...nqSOjQIW8Yby24qC_AOCdDuZacqHLMxxoCgSYQAvD_BwE
2nd question
07-10 gt500's run coolant for intercooler from heat exchanger through the expansion tank then into the intercooler. 13-14 gt500's have a bypass hose so that the coolant doesn't get routed through the expansion tank. I have to assume the bypass hose added to later models is an improvement over the previous years configuration. I am thinking I should model my coolant hose configuration after the 13-14 gt500. Anybody have any input/experience with this?
I also read on DOB's website about relocating the pump to be closer to the inlet for the intercooler because the intercooler will be the most restrictive point in the system so I want the highest pressure in the system to be at the intercooler, that a lot of aftermarket pumps attach to the side of the expansion tank to accomplish this. I am not planning on spending 350.00 on a high volume pump that this could be done with. This mounting of the pump on the expansion tank as an upgrade to cooling system makes me question if the bypass design of the 13-14 gt500 is worth the hassle? Has anybody relocated the oem style pump from the heat exchanger (lower on system) to up higher and closer to the intercooler? I would imagine if the pump is moved up in the system it would need to be someplace where it would have coolant constantly being fed to it like at the bottom of the expansion tank? Sorry for the marathon post just trying to sort things out and design the best system the first time!
Joe
2nd question
Joe
