Flusher
- Joined
- Apr 26, 2016
- Posts
- 527
- Reaction score
- 250
The procedure for setting the pinion angle would be exactly the same regardless of what type of misalignment coupling you have on each end of the driveshaft: measure, adjust, and repeat as required.
I would suggest, since you are going to be under the car anyway, consider having a driveshaft made by a local shop.
I would steer away from a CV joint, IMHO they are for soccer moms who don't peace and tranquility disturbed while driving to the mall. There are plenty of quick and fast cars turning high RPM running u-joint driveshafts without issues. Look under any high-powered vehicle that employs CV joints and you will see a massive joint, about 5" diameter. Not that dainty little 2-1/2" joint.
I would also not consider a double cardan driveshaft. You will never experience excessive joint angles in a car, like you would in a 4x4, assuming your angles are close.
Regardless what one-piece driveshaft you go with, adjust your angles to 3-degrees down pinion angle and 1-degree down at the transmission. Adjust the transmission u-joint angle by shimming the transmission mount if necessary. I try to average the angles by adjusting with drivers weight and a half tank of fuel.
As stated above, the pinion will climb the ring gear and the pinion angle will straighten out. Meanwhile the transmission joint angle will slightly increase with anti-squat.
To measure for a custom made driveshaft, you will need a transmission slip yoke and a pinion yoke. Insert the transmission slip yoke all the way until it bottoms out, then pull it out 3/4" so that it doesn't bottom out during normal suspension travel. Measure the center-to-center distance of the u-joint caps. I prefer to do this while the yokes are horizontal. You can preset the pinion angle with a string tied between the two yokes.
This site has some great driveshaft tech info http://www.4xshaft.com/techinfo.asp
A good video on u-joint phasing
Cheers,
Cheers,
