MilehighGS
Tires are a little big for the wheel width, but I got a screaming deal.What size/brand tires are you running? Those things look THICK!
305/30-19 Yokohama Neuovas.
Sent from my SM-G975U using Tapatalk
I finally got around to replacing the 2 springs in the trunk. The rubber feet fell off and some times the trunk wouldn't pop open. It surprised me how much a difference the 1/8" rubber bumpers made. Still haven't installed those damn jacking rails.
No rub. I went from staggered to this setup, I'm liking the look. ThanksI considered going with 305s but decided to go 285s. Any fender rub issues? I just like the way that looks!
I just want to confirm that’s square tire size?Tires are a little big for the wheel width, but I got a screaming deal.
With my 305s, I understand that my wheels should be 19x11 to have a "square" setup. I should have 285/35-19 for my 10s.I just want to confirm that’s square tire size?
I need tires for my staggered 19x10 and 19x11
Sent from my iPad using Tapatalk
Shelby scoop on
I would be curious as to know if you notice\experience any difference in either clutch feel or shifting feel from installing this air deflector cooling duct. I had 1 of these in my wish list on CJ Pony Parts to buy for quite some time but haven't pulled the trigger yet.Shelby scoop on
Anything that cools a trans down has got to be beneficial right? [emoji106]I would be curious as to know if you notice\experience any difference in either clutch feel or shifting feel from installing this air deflector cooling duct. I had 1 of these in my wish list on CJ Pony Parts to buy for quite some time but haven't pulled the trigger yet.
And I FINALLY installed my Steeda jacking rails. What a pain in the ass. I thought I'd never get those damn front bolts out and back in. Turns out they sit a little lower than expected. I have to rock the car up to get my jack with the puck under there. Without the puck it's fine but that powder coat wouldn't last very long. I'm still glad I got them. Tire rotation and oil changes will be a lot easier without having to line up the jack with the notch on the body.
