Dennis Thomas
- Joined
- Aug 6, 2019
- Posts
- 58
- Reaction score
- 8
Any good aft and boost gauge guide installs around here. Sure I can figure it out but it’ll quicker hearing from another s197 owner
I guess I should have asked what specific details you were looking for? Sbj on the passenger side foot well is where you will pull power from with a add a fuse. A/F sensor will go on driver side header at 1 or 2 o'clock. You will need a bung welded in for that. Lito told me where to place it. A firer wire is a good idea if you're going to data log for remote tuning. Boost well depending on if you are doing mechanical or electronic, I choose all electronic from Speed Hut due to options, looks, and quality. That pretty much covers everything except were you want exit the car with them. I choose the driver side foot well but there a spot behind the radio if I remember correctly. That's a good spot for A/F to exit. I am sure theres more. If you have other questions I'll try to answer the best I can depend on what you need.Thanks
