Can you provide spec’s on the buffer you are using ???That'll buff out.
Its more of a magic wand. Paging Harry Potter....Can you provide spec’s on the buffer you are using ???
Somebody please explain to me how a curved STB between the shock towers does anything at all besides add bling.Notice the STB appears to be intact....(+ driver's side shock tower). Ditto with driver's side tires. I have seen mustangs with + without STB's....that have been involved in accidents. The ones with STB's fare better.
The minor possible movement between the two shock towers cant possibly be reduced by a curved brace. It will just deflect up/down in the center as the towers/chassis flexes.
Maybe if it was a straight piece, I can see it. Curved, its just bling.
