Fuel pressure sensor delete
nickburns31
Hey folks - Unfortunately I bought a used procharger and haven’t had much tech support from them. I also installed a new Aeromotive Inc fuel system with dual fuel rails and a a1000 pump. Is there a way to delete the FPS that was on the fuel rail? I put new larger fuel rails on the motor.
It can be, but that's a tuner thing like mentioned. Most like to keep it to monitor pressure in logs etc.
nickburns31
I ended up calling aeromotive inc and they had an adaptor to use inline ... perfect setup
07 Boss
Sin City
This is what you will end up with. I have mine right after the distribution block where the lines split for each fuel rail and where the fuel pressure gauge sensor is located.
nickburns31
Thank You for the idea - It’s been one thing after another buying a used procharger - According to my Wideband O2 meter this thing is running extremely lean .... I did put 60lb injectors in it and using my SCT X4 made it 14% richer but it doesn’t seem to change. I put the O2 sensor right above the CAT, the exhaust doesn’t leave much room for the desired 24” from the exhaust port. Any ideas how to lean this out before I break down and take it to a tuner ( Who BTW hates Aeromotive inc and their products ) hence I have been hesitant in taking it down there. According to my LM2 I’m running a deadly 25 - 28 AFR
Juice
There is NO WAY you are running 25-28 afr. The car cannot run that lean.
nickburns31
I must have a setting wrong on this Innovate LM-2 - The O2 sensor seemed to calibrate fine ...
Juice
Check fuel trims, short term and long term.
