DieHarder
- Joined
- Nov 9, 2019
- Posts
- 1,467
- Reaction score
- 758
If you're talking about the relay itself the most common type I've seen in my car (2006) is "B" on pg 5-8. To test it refer to the chart on the bottom of the page. Using a VOM you should be able to see voltage between pin 30 - gnd; then key-on to see voltage on pins 86, 87.
For the 0690 use the test procedure. B1 advises if you have DTC 0690 go to test B13 and follow the procedure for the PMCRC resistance check. If I'm reading it right use continuity/ohms to test resistance from B35 to ground (use the body ground on the passenger shock tower). If that's good then go to B14 (Ignition Switch Position - Run; ISP-R). If the rest of section B checks out we can pursue a No-Start condition (Pinpoint test A) except that the engine does start for a second or two but won't stay running. Best guess is something mis-wired or shorted.
Did you find anything going over the harnesses?
