"Snarky much?" Yes, I'm tired of total noobs pushing bad info on this page, like quoting some absurd 12.1 pound wheel for a Mustang, or that running a 255mm tire on these heavy cars is ever a "good idea".
That's just BAD TECH and BAD ADVICE.
Am I giving "horrible advice" about Mustangs going to a 305mm tire? No. Look at costs over the life of the tire. And wheel costs, too. An 18x11" Apex wheel is not much if anymore an an Apex 18x10" wheel. And a 285/35/18 tire comes in MANY fewer choices than a 305/30/19 - which has dozens of options. There's a reason why so many S197 and S550 Mustangs end up on 19x11" wheels. They fit and tire choices are abundant.
A decade ago I listened to the
bad advice on this page and others, and we started with an 18x9" wheel and 265mm tire on our 3600 pound 2011 GT, shown above. There was an autocross class that limited us to that, which we tried for 2 seasons. Driving on the skinny tire and wheel was a HOT MESS - literally, in 30 seconds of an autocross run we could turn the rear tires into boiling goo, then the car was sideways like this for the rest of the run.
It was just as bad on track when driven hard, as shown above on the same
18x9" / 265mm tire. Don't fool yourself - driving a heavy, powerful car on a skinny tire isn't "great instruction", it is maddening and futile. With 430 whp it can be "less than safe", too. I did this nonsense on track for a whole year running NASA TTB and it was SUPER frustrating.
Skinny Tire Syndrome makes you slower than the rest of the pack, so you're getting passed all the time, which is stressful. Your lap times are erratic because the skinny tires are overheating sooner, even driven with modest talent. There is nothing "noble" about hobbling your car like this. There isn't much if any cost savings, when you look at the life of the skinny tire vs the wider tire: skinny tires wear faster than wider tires, on the same car. We've shown that over and over here.
As we moved from a 9" to a 10" to an 11" wide wheel on our S197, and the tire sizes going up from 255 to 275 to 315mm, the Mustang got EASIER to drive, lap times got faster, and tire wear improved. Consistency from lap to lap also got better. THAT IS HOW THIS STUFF WORKS.
I am trying to keep people from making "iterative" wheel purchases. They go from a teenie tiny sad little stock wheel to 18x9" to an 18x10 then to a 19x11"... meanwhile they are getting passed by Miatas on 205mm tires the whole time they are "coming up through the ranks", get pissed off, and
some will quit the sport.
Too salesy? That's easy:
Don't buy wheels from me. I don't even push our wheel brands anymore, due to unbelievable delays with the manufacturer. I keep pushing people to Apex and other wheels, which I don't sell. And to 305-315mm tires, which I also do not sell.
Don't hobble yourself needlessly with a narrow tire and wheel packaging thinking this is some "good thing". It is not.
A 3600 pound Mustang is HEAVY AF and needs more than a 255 or 275 or 285mm tire. Yes, even noobs will have more fun on a 305mm to 315mm tire, because they won't be OVERHEATING skinny tires and be a ROLLING APEX, going slow on skinny meats. Our S197 eventually went to 18x12" wheels 335/345mm tires and... guess what? It was a lot faster, easier to drive, and the tires lasted a lot longer! Our class track records we set on 315s dropped by 2-3 seconds. Wider is better - THAT IS PHYSICS.
Why is that? Tire width and weight go hand in hand. Meaning: the heavier the car the more tire you need to make equivalent grip. Well let's look at the most common size tire used on a
Miata: 205mm. Sure, many run 225mm, but lets stick with that 205 tire, as it is the widest you can
easily fit on this chassis. The standard, noob track squid in a Miata is on a 205mm tire. We have built and driven lots of Miatas, like this one above (on 15x8 / 225mm tires).
To be the same
weight-per-width ratio as a 2400 pound Miata on 205mm tire, a 3600 pound Mustang needs a "307.5" mm tire. That is weird, right?
No, that is just simple physics. This is why we have a big push towards 305/30/19 on a 19x11". It is the widest tire you can fit under stock fenders and readily available in dozens of choices. Or run an 18x11 and 315/30/18 - there just aren't nearly as many tire options in this size.
A 305 or 315mm tire isn't a "big tire", it is barely
equivalent to a 205mm tire on a Miata. That's what even noob track drivers in Mustangs should use, yes. Can't afford a 305/30/19? Then go buy a Miata and run 205mm tires. If you are tracking a 3600 pound car with a V8 you either use the biggest tire that fits or you get lapped by Miatas. That's the reality.
Get your heavy pony onto 305-315mm tires and you can at least reach GRIP PARITY with the lighter cars. That's how we make a fat ass 3600 pound Mustang keep up with and even PUSH lighter cars in corners, like above at the 2018 NASA Nationals. The TT5 car weighs a good 1000 pounds less than my S550, and he couldn't believe when this big tank was catching him
through the corners. There is no reason why you can't make a heavy car keep up with Miatas and other light cars cornering - you just need as much tire-per-weight as they have!
Ignore my advice, sure. Listen to the scrubs who have never won a race, never set a track record, never done anything of merit. Great. You will be cannon fodder for Miatas on track.
Do I sell things? Sure, and I don't hide that fact. We barely sell wheels anymore, and if we never sell another set, it's no sweat. We're a suspension shop, first and foremost. I say this a lot: TIRES IS ALMOST EVERYTHING when it comes to autocross or track potential. Everything we do on the suspension is to MAXIMIZE THE GRIP FROM THE TIRES. It sucks to sell someone really nice suspension bits then see them hobble the car with teenie tiny tires. Don't be that guy.
Cheers,
