New to S197's, not to Mustangs. Starting a lightning swap!
Gerbil N7
Hello all! My name is Andrew and I just bought my first s197 Mustang :) It's a rebuilt car but I have plans for something interesting. Through a semi-interesting story, I came into possession of a 2nd generation Lightning motor that I'm going to try to swap into my 07 Mustang v6 car to make a street/course car. Any tips or advice is MUCH appreciated and I can't wait to get to know some of you!
Juice
Going to need a new trans, driveshaft, and rear besides the engine. Not up on Lightnings, is that a modular or a windsor engine?
Dino Dino Bambino
I have a red car
Cyprus
The Gen 2 Lightning had a supercharged 5.4L 2V Modular V8 producing 360hp/440lbft (1999-2000) & 380hp/450lbft (2001-2004).
Juice
i like the 5.4 2v, got one in my van.
So it should be pretty much a direct bolt in, with a trans driveshaft and rear.
Gerbil N7
Holy cow, wasn't expecting this many responses so quickly lol. I appreciate the enthusiasm. Hopefully it's not too rough of a swap. I have a trans, driveshaft and rear end ready to go. The only thing I'm really questioning is what PCM and wiring harness I'll need. I also have to replace battery cables and a lot of interior things because it was a salvaged car that had a lot of things stolen off of it while it was sitting in a guy's yard...
Juice
Im pretty sure using a GT pcm is the best choice. Tuning will be required, and vct needs to be disabled.
SVTom
I have had a couple Lightning’s over the years.
99 and 03.
Heat soak was definitely a problem. I always thought it was the heat exchanger back then.
Joe combs
Northern Kentucky
Besides what has been mentioned, the other thing you are going to run into is engine height due to the Gen 2 Lightning supercharger. Another thought to consider is the weight of that engine combination. You said you had a transmission but didnt mention what trans you plan on using.
