Can’t find 3 inch crossover pipe
Jake Schmale
Cincinnati
Hey guys, I’ve got Hooker blackheart 1-3/4 inch headers and for the life of me I can’t seem to find a 3 inch crossover pipe for these headers. I’m currently running straight pipes into flowmaster super 44’s dumped under the car that are rattling against the floor due to the lack of mounting locations. Does anyone have any suggestions?
07 Boss
Sin City
I'm a little confused. A 3" steel tube doesn't work for a crossover?
Weld in some hangers if your exhaust is banging around.
I'm not sure what you are asking here. Seems kinda simple, what is your difficulty?
Forty61
Dallas, TX
I’m a little confused too..
OP, do you mean your headers have a 3” collector and you can’t find a 3” mid-pipe? If that’s the case and you’re running from the headers straight to the over-axle pipes with no hangers in the middle I’m not surprised it rattles!
EDIT: I see you said the mufflers are dumped under the car? Like under the rear seats? Pictures would go a long way..
Doug Huggard
California
I did some searching. I couldn't find just a midpipe, but I found the exhaust system meant to pair with your headers here:
https://www.summitracing.com/parts/hok-70503342rhkr/year/2006/make/ford/model/mustang
Flusher
A local muffler shop could simply add a crossover to your existing setup, probably for under $100
Flapjack
Lunatic engine swapper
Colorado Springs, Colorado
To echo the others... it's hard to know what you are looking for, but I ended up using a 3" Magnaflow crossover (part #10792) and a 3" Magnapack (part #16674) for my system.
ghunt81
New parts on old junk!
Clarksburg, WV
JBA makes a slip fit 3" H pipe, chance that could be made to work.
Iceman62
Bullitt 6005
NE
Another vote for (1) what's your goal & (2) go to a local exhaust/muffler shop...good luck!
