saleen836
Today was the first day i have managed to get the car out for a good drive, now driven approx 100miles with the new drive shaft fitted and Saleen ss kit removed,when pulling away I have had to be wary as it is now a lot lighter on the clutch,initially it took a while to get used to the longer throw but it actually changes gear easier without the Saleen ss kit so at present i'm not bothered about getting a ss kit,it definately accelerates faster with a downside being even in the dry it is a lot easier to loose traction
As I am running a 3:55 rear end the car now will sit easier at 50mph in 5th gear where as before it would struggle a bit and I would have to drop down to 4th,over all an upgrade that is deifnately worth the expense and it is a mod I am happy I have done.
Thanks to all those that have commented with help/advice
