2019 Stereo install, not sure what this is
Flapjack
Lunatic engine swapper
Colorado Springs, Colorado
So... I'm wrapping up installing my Pioneer DMH-WT8600NEX in my 2019 GT, but there are a few things left to ponder.
One is a mini-USB plug that goes into the back of the factory stereo. I have no idea what it's for, and my Metra 5838 dash kit has no provision for it. I called them, and they also had no idea what it was. I've attached pictures of the plug and the spot it went to on the stock unit.
Also, I was hoping someone could verify that the red antenna cable behind the dash was the XM radio antenna, and not the blue one with the same connector (which came off the old radio, so I'm assuming it's the regular AM/FM antenna). You can see both in the first pic.
Thanks in advance!
07gts197
Naples, Fl
Flapjack
Iceman62
Bullitt 6005
NE
If you don't want to lose USB, they make f/f adapters...just say'n.
