DieHarder
- Joined
- Nov 9, 2019
- Posts
- 1,467
- Reaction score
- 758
I did find out my cowl drain right below the windshield wiper motor was almost completely clogged with junk. Did you check that on yours?
Yep, there's one on each side. Easy to clean them out from the bottom or if you're adventurous take the plastic cowl off and contort your arm down in there to ensure you've gotten everything out. If you're going to go to the trouble of removing them might as well replace the cabin filter on the driver's side while you're at it.
