You might call Chris at BBR and have a talk with him. I had a bad tune from a different company and BBRs tune fixed it. It felt like it was falling on its face around 3K. It was around $75. My 2 cents. Hope you get it figured out, once you do, the manifold is great
Shouldn't that be the other way around? The fronts are the ones the ECU uses to adjust A/F. The rears are for emissions. At least that's how it is on the older computers.
I had a similar problem and replaced my o2 sensors and all was fixed. The passengers side basically clogged up on me meaning failed reading properly through certain rpms at certain throttle pressures. It all started when I put on my frpp manifold as well and the car just freaked out on me i guess and the o2 sensors went out lol. So I just replaced the rear 2 and all was fixed. The front 2 I have off becaue of my long tubes so I didnt worry about them
Could it also be in the tune for the o2 sensors? Meaning like maybe they didn't make the tune aware that the o2 sensors are moved further downstream, thus causing an issue with reading exhaust flow correctly especially at certain rpms?
My tuner put the car in open loop and rewrote all the fuel tables and cam angle. Car ran flawless. No spikes, no backfires, absolutely perfect. I also used to have a startup issue on cold-starts after the car had sat overnight, the engine would rev up to 2800/rpm and sounded like dogshit as if it was backfiring the whole way 'til it warmed up a bit. Now it starts up at 1400/rpm and idles perfect. I also had an issue with idle surge/crash when coming down from gear, I'd be rolling the gears and say I was at 2500rpm and let it go to neutral, the rpms would fall all the way to 350 and then surge back up to 1100 and it would go back and forth like that until I came to a stop, then it would idle fairly normal. Now I can let out anywhere and the car drops to a perfect 850/rpm idle.
Sometimes my car does the same thing. I noticed when I would go to start it in the morning it would slowly rev up ~2500-3000 rpm and sound really bad like the car was stuttering. It hasn't done that for awhile now.
It does, however, idle like yours when coming to a stop. In the morning when I go to work, when I leave work for lunch, after any period of time the car sits, it idles so low it almost dies and then fluctuates upward while driving/coming to a stop, and up-and-down until the car finally warms up.
I wonder if it could be my tune (BBR) even though it just recently started the fluctuating idle issue once the weather cooled down, or if it's the O2 sensors. The start idle issue has only occurred ~7 or so times since April, which is the time I put the cams in.
I recently cleaned the throttle body and tried reinstalling the tune to no avail.
With L/T and no cats I don't think your O2's aren't getting hot enough, so the computer keeps adding more fuel. I had a similar problem with my TT setup and ended up moving the O2 sensors as close to the turbo out as we could and still had to set the tune to run open loop until the sensors reached a good temp.
Earl
O2 sensors were bad.Ever find the solution?
I seem to be having a similar situation
