1950StangJump$
- Joined
- Apr 1, 2010
- Posts
- 966
- Reaction score
- 108
But I already said "whatever" and moved on.
Any other questions sir?
Yes, just one .... when, exactly, did you move on?
See my post with "whatever". The post where I told him why he cant progeam PATS.Yes, just one .... when, exactly, did you move on?
There is no PATS module. It's the IC you will be dealing withwe were still not able to connect to the PATS.
Instrument Cluster.What is the IC. IF I get a 11-14 cluster what would happen?
This is an underrated comment.You'd also perform a compression test on all cylinders to ensure they were all within 10% variance, check there are no abnormal noises, and use a mechanical gauge to verify that the oil pressure is good before adding any mods beyond headers and perhaps a CAI.
