Hey all. So I'm putting my new engine and trans in and I bought every sensor brand new from ford. However, the knock sensors they sent had two separate connectors while the harness has a single 4 pin connector. So, I ordered the right one from LMR. I got it today and the connector is correct but the brand is Standard part number KS189. I'd rather use oem but I have no idea where to get the right one and I'm not sure if I order it from somewhere else if it will be the right one. Are Standard sensors subpar or are they as good as oem?
Sent from my SM-N986U using Tapatalk
