MT ET Street sizes
Laga
Chicago
05 GT with Edelbrock E-Force @ 8-9# of boost and E85 Lito tune, 3.73 gears, automatic transmission with a TCI 2800 stall converter.
Currently, I have 295/45-18 Nitto 555G2 on the back, and 255/45-18 on the front. They are ok at road course track days, but they are useless at the drag strip. I want to get a set of MT ET street drag radials. I don’t plan on any bracket racing, I just want to be able to run decent times and not waste my time at the drag strip.
I have to stay with 18” wheels to clear my Wilwood brakes. There are four sizes available to me that should fit 275/45-18, 285, 305/40-18, and 305/35-18. Which do you think will give better traction? I think it will be the 275’s.
MrBhp
I was running 225/50/16 Hoosier dot drag radials before my brake upgrade. 1.6 60 ft. Several inches of air under the front tires at launch. I say run the narrowest/tallest tire. Good wrinkle light weight. I have adjustable shocks/struts. Full stiff in the rear, full loose in the front.
Midlife Crises
Not exactly what you asked but when I was looking for Mickeys I could not find them. Still can’t find them in stock. Soooo, I shitcaned the 555G2s I had on the back and replaced them with NTO5s. 315X45-18s do fit on 10” wide wheels and are far superior at inline traction. They don’t rub on my lowered stang but they do poke a bit. If you jump on them in the rain the ass will pass you. :)
Laga
Chicago
Narrow and tall, that’s what I was thinking. I have Strange adjustable shocks on the rear. With the Nitto’s, I got bestresults set on 3 out of ten.
Laga
Chicago
Yeah, i was looking at both MT or NT05. Discount tire by me can get MT’s in five days. I got plenty of time though , wife just had shoulder surgery and I won’t be going racing till July at the earliest.
07 Boss
Sin City
I've run every drag radial out there and found the best results were from the MT Street R. The NT-05R were one of the worst. I would run the regular nitto DR before the NT's, but neither of those will compare to the MT Street. I always have gone with the widest tallest tires that I can fit and then do the rear end gearing to compensate. So with my 305/45/18's I run a 4.11 gear but my effective gear ratio is about 3.83 which is pretty good for my blown automatic.
Laga
Chicago
With the 3.73 gears, would not the 275/45-18 be the right size?
07 Boss
Sin City
There is no right size. It all depends on what you want your final drive ratio to be. Some people prefer a taller gear and some a shorter. Just always figure tire size into your calculations as it will effect your times. I think I used a conversion chart on a 4wd website or a drag website.
Laga
Chicago
I’ll rephrase, since I’m not going to be changing gears, would not the shorter tire be a better choice?
07 Boss
Sin City
It all depends on what you want. I was looking for about a 3.90 gear ratio so I went with 4.10 gears and a 29" tire. If you want to keep your final drive ratio the same as it is now stick with the stock tire diameter. If you want a shorter gear or higher ratio go with a shorter tire. If you want a taller gear or lower ratio go with a taller tire.
