If you didn't solder the wires back together you will have an issue. The signal is low voltage and must be soldered.
Good job on doing things improperly and actually they dont work as well. Learn about voltage drop and come back and talk to me.I've used butt connectors on most circuits on my cars. When properly crimped and insulated they work as well as soldered joints. You're more likely to have a problem with a cold solder joint then a properly installed crimp joint.
Sorry but not true at all. Do you also think these are functional?I've used butt connectors on most circuits on my cars. When properly crimped and insulated they work as well as soldered joints. You're more likely to have a problem with a cold solder joint then a properly installed crimp joint.
