Bank 1 is adding fuel, and I believe it has pegged, thus the system lean code on that bank. Since bank 2 is perfect (no correction on long term) it is possible that O2 sensor is starting to fail. Or some other issue on that side of the engine.
Swap the two upstream sensors and see if the same code comes back, or changed to the other side.
