Man.... 2007-2008... that post would have gotten someone roasted and maybe banned here...Ugh ....
the pic of the graphicsWhich post Dave? The picture or the Ugh?
...also need a passenger rear seat belt latch...this one will not stay buckled. It was used once in 07 and never again until I we had kids. I have taken apart a couple times but only latches the first time. No idea why.
Sent from my SM-G996U using Tapatalk
It's been that kind of year. I have had mine out a lot less then last year. Sad but getting close to putting it away for the winter, unless we have several very nice days... still early we will see.This weekend I took our 05 GT out for a rood trip to Summit in Arlington TX .
Sad thing is last time we drove it was in May.
Had my son swap out the replacement wiper blades i picked up a few days ago. With a folded towel placed on the glass under the potential impact point, of course [emoji16]The rear axle job is back on hold for a couple of days, so I decided to tackle one of the other little tasks.
Some time ago I'd pulled part of the interior trim and carpeting up due to the water leak. Today I started putting that stuff back in. It took a while to figure out where the passenger side seatbelt wire connected to the harness, and it's not shown in the CD-ROM version of the FSM. Took some more time to find the push-pins, which I knew I'd saved somewhere.
Norm
Norm
220 lb/inHey Norm, I know you’ve posted it before, but what spring rates do you run on the rear of your S197?
220 lb/in
They're the BMR GT500 Handling Springs (20 lb/in stiffer than BMR's non-GT500 rear springs). I got them as part of the #SP-072 kit but they are #SP-074 for the rears alone.
They also dropped the rear of my car by about 1" vs the advertised 1.5", presumably due to the difference in GT vs GT500 car weight. I've since taken most of that 1" drop back out for axle roll steer reasons, so the rear of my car is almost all the way back to its stock height.
Norm
Stock weight, whatever that was. I've never got it weighed but I haven't made any changes that affected the weight by more than a few lbs or so.Is your car still at stock weight? By raising back up, what is your expectation, promote roll steer or eliminate it?
It's not the lack of rearward load transfer - that happens anyway. But it may be happening too suddenly, or maybe you're getting into the throttle a little too early. How much rear sta-bar are you running? Any LCA relo brackets?My car weighs 3290 pounds with a 1/4 tank of fuel. My rear springs are 225# coil-overs. It seems a little stiff in the rear. I’m considering going to the 175# springs that I had on the car before. They are Steeda sports that just happen to be the same dia. and length of the 225s.
It handles well as it is, but traction off the corner is far from optimum. I’m wondering if it’s from lack of weight transfer.
