golkhl
Double check that trans fluid is not leaking out of where your speed sensor gets installed in the transmission. My 94 and the 89 I am working on now, both had this leak.
Thanks man. I had never heard about this until recently so will definitely be taking a look at the PCV valve.5.0 Fox Engines are known for upper oil leaks that appear to be The Rear Main Seal. Behind the Intake where the PCV goes remove the PCV valve. Replace the Valve, The screen in the intake and the grommet. If the screen gets clogged it causes oil to push past the rear lower intake seal. Appears every time to be a Rear Main Seal.
I wish this were true. I'll document more in my next video but there's definitely still some oil leaking. I need to get the car elevated and get underneath to clean things up more and see what else it could be.You just fixed your oil leak. Unless your rear intake is leaking as well.
Thanks for mentioning that. I'll do some investigating.Hey Dude, take a closer look at your tail shaft seal when you get under the car. Yours does does appear to have the dust boot, with all that oil in the tunnel and on the exhaust, you might need a new one.
As for the oil leak out of the bell housing…..your rear mail seal might be f.u.b.a.r..
