TheFourSixThatCould
Ok so ive been reading for a while now and can't seem to find a definite answer people agree on. I'm planning on getting bc-br series coilovers soon but cant figure out what spring rate to run, I do a lot of spirited driving on the roads, but this is also my daily driver so what spring rate would you guys recommend for the best mix of the two, and if not the br series bc what coilovers for about 1200 would you guys recommend as i will also want camber the front about -3 degrees and lower the car significantly as the lowering springs i have now aren't cutting it anymore. So, any advice for spring rate would be recommended as I'm thinking somewhere around 7k, but again no have experience lol
