Is this a full system or tuner kit (fuel system upgrades and tune not included)? Suggestions and tips will vary greatly depending on what you are installing.
That's true of all forced induction setups. What matters is how hard you can run it before that happens.I don't mean to sound like sour grapes and I'm no mechanic but I have heard that if you install this system when it becomes heat soaked your advantage dwindles. Just saying.
You might want to think about putting a larger pulley on your alternator or you could find it breaking down in a short space of time
Stops the alternator spinning to fast and failing, I believe the Saleen SC kit comes with a different pulley for the alternatorWhy?
My shop called Brenspeed and in this particular set-up the fuse had to be upgraded for the Paxton 2200SL paxton.I have a boost pump since 2007. The fuse has never blown. Maybe the wrong fuse was included; however, I would recommend against doing that from the get go. Fuses are sized by the wire they are protecting. Contact the vendor to see if they've had a fuse problem, and then go with their recommendation.
