pass1over
I like it LOW
Can you give more detail on loading your data into it?
I saved my ASBUILT data from my ABS unit onto my laptop. You go into PATS, Module Initialization, and then click ABS module. It will initialize it through a approx. 12min process and then you can import your ASBUILT data into the new module.
If you just install the used module, you'll get more codes than you started with as the car doesn't recognize it.
