graybeard
2005 GT Coupe......
Checked codes: No stored, pending or permanent codes.
No check engine light.
Could you post the Ebay seller info? I have the same issue on my car's dash.Got tired of liking at the broken dashboard defrost vents and ordered a kit from eBay.
It’s not perfect but better than looking at a hole with broken grates. Now need to figure out how to cover the dash cracks?
View attachment 116231View attachment 116233
checked EBay for this seller\part................seller\part doesn't exist anymore but I found this 1:I have had it sitting in the garage for about year... not sure if the guy stills makes them?
Here is his install video and info.
Kinda figured it was cheaper thus hoping that he was still listed & selling.I think it was Blue03Cobra posted who posted that full length metal one last year... see if they can provide any input.
I sent my seller a message via eBay to see if they still make them... I think it was like $50.00 last year?
FYI for those so interested.....................Checked degas reservoir this morning while setting out trash for coolant level on fully cold engine & block valley area for signs of leakage..........cold coolant level was in center of the cold fill range & block valley area under IM was bone dry, so parts & repairs are verified sound. All good so now I can rest assured that this is fully resolved going forward.......
Guilty as charged. My issue was the defrost "vent" had cracked, but only enough to rattle...annoyingly. i actually used hemostats to remove all the fins and the metal one (using vct) perfectly covered the, now gaping, opening. About as good as I could have imagined.I think it was Blue03Cobra posted who posted that full length metal one last year... see if they can provide any input.
Off topic: MDs like to diagnose carpal tunnel syndrome, because they can generate lots of money with a hand surgery. Often it is a thoracic outlet syndrome which can be treated by physiotherapy and simple shoulder workout instead.carpal tunnel
Yep........tis the reason why I told the doc some 30 yrs ago, that as long as I still have full range motion in both hands\fingers that I'm not gonna have the surgery performed.Off topic: MDs like to diagnose carpal tunnel syndrome, because they can generate lots of money with a hand surgery. Often it is a thoracic outlet syndrome which can be treated by physiotherapy and simple shoulder workout instead.
Ask me how I know![]()
How do you like them? Mine are nice and quiet at 60mph but the resonance at idle was HORRIBLE with my long tubes. I had some resonators put in which helped but it wasn't till I got the centri that it finally got better. Still pretty bassy at idle but not nearly as bad as it was.I swapped out the Borla Stingers for the Borla Touring. And went over the entire exhaust tightening up all the clamps. The pic of the quickjack was at the lower setting when I took the pic. I raised it to the max height when I went over the entire system.
I am not sure. I haven't even taken it out yet with all the foul weather here. I don't drive this car in the rain. I am sure they will tone down the exhaust some but I know I still have more work to do to make it suit my tolerance. My warm idle was actually tolerable even with the Stingers but once I got to 1500RPM+ the groan was a bit obnoxious. If these help that mid range rpm drone some, than I will be happy. We shall see. I am expecting an improvement but nothing perfect. Once I see how it performs, I will make more adjustments if necessary.How do you like them? Mine are nice and quiet at 60mph but the resonance at idle was HORRIBLE with my long tubes. I had some resonators put in which helped but it wasn't till I got the centri that it finally got better. Still pretty bassy at idle but not nearly as bad as it was.
This one *is* mine and carbs and loose wiring has been taking up most of my time
I am having a Carpal Tunnel Procedure this Friday 6-5Off topic: MDs like to diagnose carpal tunnel syndrome, because they can generate lots of money with a hand surgery. Often it is a thoracic outlet syndrome which can be treated by physiotherapy and simple shoulder workout instead.
