06 to 09 door help
whitmanink
denver pa
i switched everything over to the gt to make it good , and i used doors out of my 06 v6,, now nothing works on the door, no mirror , no window, no locks, i checked the fuse for the jsb and all is good,, the 09 doors worked before i switched them,??? its a 2009 45th gt .. thanks guys
sure you didn't miss a plug connection when reassembling?
whitmanink
denver pa
the only plug is the main plug that plugs in at the door \ frame ,, its one big one with a lever lock , so im clueless as to whats going on,, its an 09 gt 45th addition if that helps'
whitmanink
denver pa
so i just put the 09 door harness into the 06 door, everything works now,, the part numbers on the harness's are not the same ,, so that makes sense why it wasnt plug and play .
