Sparrow07
- Joined
- Feb 25, 2019
- Posts
- 12
- Reaction score
- 0
Hello everyone, I am new to this forum, and my car for that matter and am having some issues I need some help with.
I have a 2007 mustang gt that I bought recently with about 62,000 miles on it. It ran good when I bought it but, the check engine light was on. So, I went and had it read, and it had codes for a cylinder 2 misfire, cylinder 8 misfire, and one meaning the throttle body needed cleaned. So I took the throttle body off and cleaned it, and then decided to pull the plugs and change them. Somehow I got all of the plugs out without any problems, I don’t know what was causing the cylinder 2 misfire other than the fact that it was a little loose; however, it was pretty obvious what was causing the cylinder 8 misfire as when I pulled the plug the tip and electrode where broke off. Now that caused some concern; however, it did not look like it happened recently, and I used a bore scope to look for damage, or any pieces and everything looked normal, so I assumed that any damage that was going to be done had already been done, and it had been ejected. So I replaced all of the plugs, and the car ran great, better than ever for a while.
Then a couple weeks later I started having my current problem, which is, the engine will start having a really sluggish acceleration and what feels like a bunch of hesitation, it also idling very rough, and I can feel the whole car shaking back and forth as if it had a big Lopey cam in it. The exhaust also has this very peculiar smell to it, much different than normal, maybe like a sulfur smell. The engine also makes a really loud ticking noise coming from both sides of the engine. I have tested all of the ignition coils by pulling them out one at a time, and they all changed the idle significantly, so I think they are ok.
And the weirdest part of the whole thing is that all of the symptoms come and go at completely random times. It all started randomly when I was driving one day, and then went away about 5 minutes later and then came back a couple days later and lasted until I shut it off and then came back to it a few hours. Then it ran good for about a week and now has done it again twice today.
So, if anyone has any suggestions on what it might be or what I can check all help is appreciated. I am completely stumped by this problem.
Thanks
Thanks
