Adjusted the idle again, much better now. It was hanging slightly when I had it a bit too high, so bringing it down seems to have that sorted out.
Got some NVX 5.25 components mounted up front, mounted the tweeters to the sail panel. I wanted to flush mount them in the A-pillar but that wasn’t going to happen due to the curvature of the pillars. I ended up surface mounting them on the sails, too thick to flush mount. I have them hooked up to that old school PPI amp. Turns out, the front channels on the amp are dead so I’m running them off the rear. The HU is powering the rears. I could run both front/rear off the rears but I would lose fader, not sure I want to do that. I’ll see how it plays out once I get the sub in. I have a 12” Kicker on the way, built a slot ported box today. I still have to carpet it, and hope the sub channels on the amp are good. Otherwise, I’m buying an amp. Pics to follow.
