2005 V6 brake line replacement - what size line wrench?
GuitarHero79
SE Wisconsin
I'm replacing the soft lines on my brake system with a Powerstop braided stainless steel hose kit. What size line wrench will I need to get the old soft lines off?
EDIT: 2006, not 2005. Damned sausage fingers....
This car have ABS? There were no direct fit braided lines for non-abs cars available.
Sorry, I dont recall wrench size.
Suecra
Oklahoma
The wrench you need is a 11mm and avoid using the open end of a wrench, they are very corroded due to the brake fluid that seeps into the valves so penetration fluid will be helpful.
GuitarHero79
SE Wisconsin
What do you mean avoid using the open end of a wrench? A line wrench is open-ended... am I missing something?
