Hello,
For me this is something of an emergency - especially with Christmas being three weeks away - so any help you can provide will be appreciated.
Today during morning commute driving roughly 40mph, I heard a high pitched noise which sounded like a small turbine spinning down, then immediately experienced engine failure. I restarted the car and it drove like a champ. After dropping off my wife, on the return trip it did it again - this time while taking a relatively sharp right turn.
Same high pitch spinning down sound, then engine failure. When I restarted the engine it knocked like crazy. I shut down and restarted - same knocking. I drove the car low speed trying to get it to a place I could park it when the knocking went away.
At that time I asked the car to get me home and proceeded to drive it home without issue. My back seat is off for my upcoming dynamat adventure so perhaps that helped me hear the noise. I THINK it came from the rear of the vehicle but because the pitch was so high - I genuinely can't be sure.
The noise made me think 'pump' but after googling fuel, oil, and water - I'm not sure anything I've read sounds like what I'm describing above.
The vehicle has 115,000 miles, and has been progressively reworked over the past year: Rebuilt trans, new fuel filter, removed Charge motion plates, new motorcraft one piece plugs, New manifolds, catless mids, and exhaust. A bunch of suspension work, braided lines, brakes - etc.
I only saw the normal gauge lighting one would normally see when an engine stalls. No apparent CEL - certainly nothing persistent. I have a bluetooth OBD connector I'll have to dig up to verify no stored codes.
Really though, thanks for reading this novel, and if you can offer advice - I would appreciate it. I'm really concerned about this against the financial demands of the upcoming holiday and I'm clueless as to the issue.
Any questions, please ask. I'll be checking this thread regularly...
