20x10.5 wheels square setup
shark tales
Wiggle Wiggle Memeber
Charlotte, NC
Just got done going through some boxes of joy Fed Ex dropped off this morning.
All looks good. test fitting tom and mounting tires after that.
dont mind the sub par cell pics
UltraKla$$ic
PERENNIAL WAXXER
Louisiana
All of them are +30mm offset? Mock them up today!! I wanna see how much they are going to stick out......if at all. I'm wanting to go 20x10 on all 4's but worry about the front offset choices.
19COBRA93
Ford Racing
Clinton, Ut
That's badass. Anxious to see them mounted. What tire size are you going to be running?
3.73-11
gonna look killer i'm guessing 255/35/20 stretched out on em:boobies:
I'm about to put some lame gold xxr-522s in 19X8.5" +15mm offset using pirelli 255/40/19 on my gt later today.
RedMosesSC
NYC
I have those wheels in Black, only im running 20 x 8.5 up front w a 245-40, the rear wheels are very agressive offset wise (+35 IIRC) and stick out past the fender a bit, you may have a problem running them up front...
Im running a 275-40 in the rear and its a bit stretched.
silverspec
Toronto
Curious to see what this looks like with the offset\width on these...what size tire are you planning to run?
FR500GT
Orange County, CA
Can't wait to see these mounted. I had to change my new wheels from 19's to 20x10 front 20x11 rear..they come in next week!
shark tales
Charlotte, NC
I will test fit them tom so we will see how my measurements play out. It is a 30 offset wheel. At my ride height to make this work I will be stretching 255 35 tires on it. with my current ride height and previous wheel setup I ran 0 camber up front. If it gets bad I will adjust for some neg camber. the rear we all know about I have to live with it lol
SonicBlur
]V[EGADET]-[
Wood Dale/Schaumburg, Illinois. Near Chicago
I have always wondered what silver would look like (as opposed to my Gold mesh wheels). If you car looks as good as I think it will, I may be investing in these wheels. I think the 20's will look better and fill the wheel well better than the 19's I have.
I can't wait to see these mounted!!
-Mike
shark tales
Charlotte, NC
poke is 10mm in front and 15-20mm in rear Im dying to get tires. Ill update in two weeks after I pay mortgage and other bills.
musshoss
Ohio
wow...that last pic really shows it. you gonna have a bit of negative camber im assuming to make it look right? and slammed?
shark tales
Charlotte, NC
all done guys. it was a long day but so rewarding.
I will be going .5 in lower all around and putting on 1 def of neg camber up front. as is, there is no rubbing and Im loving that.
last shitty pic before I dial it in, align it, and get a proper photoshoot
