A couple of questions from a newbie.
cc2fingers
Colorado Springs
Two Questions: Does anyone know if Hurst (or Ford) makes some sort of bushing kit for the Shelby shifters? And: Is there a dry type air filter that will replace the factory Shelby one?
Thanks!
cc
cc2fingers
Colorado Springs
And just one more> Is there a way to adjust the clutch pedal throw? I have to mash the pedal to the floor to get it to start and to cleanly shift. Is that normal?
brasil
Germany
..the pedal needs to be pushed down to the floor ..to start the car. That is correct. And for a proper gaer change..it is a good idea to use the FULL travel /way of the clutch pedal. ... also normal.
Enjoy your new "baby "
whitmanink
denver pa
i found also ,, that when i installed a separate Clutch line reservoir ,
the clutch stayed consistent ,,
this is somthing every s197 owner should do ,, its easy and should have been done at factory imo
it says 2010 and up but it works fine for our year,, its what i have cuz i didnt want to spend big bucks on the shelby one..
i can show u pics if u want ,, altho i think i did a post on here when i installed it
GriffX
Rural Germany
I remember a clutch fluid reservoir from GM that fits also.
From a motorcycle
brasil
Germany
GriffX. you are the man ! Thank you for the link... 45 ml reservoir 10.99 Euros... a real steal !
