Please post necessary part numbers and pictures!
The quick release itself fits onto any NRG hub. The Momo bolt pattern is different though, so an NRG quick release won't fit your momo hub.
The parts are as follow:
NRG Ford Hub SKU: SRK-175H
NRG V2.5 Release SKU: SRK-250B
Does this create any issue with the air bag light on the dash? I'd hate to have another light to look at...
Come on guys.. I need you to work a little harder at making this a technical thread or I am going to have to move it to the general chat forum.
To install an aftermarket steering wheel in an S197, you must first remove the stock wheel. Before you go any further, disconnect the battery; as you will be working around airbags, and they are no joke if they go off. So now that the battery is disconnected you remove the two circular tabs on the side of the stock wheel and remove the bolts holding the air bag in place. Remove the airbag and disconnect the two electrical sensors on the back of it(set it aside face up incase of an accidental discharge) Once the airbag is taken care of you remove the big ass T-something bolt in the center of the steeringwheel and pull the stock wheel off. Then put on the hub, and wire in the horn. The quick release is in two pieces, remove the "male" end of the quick release and afix it to the hub; then connect the horn wires to the quick release. Then afix the other end of the quick release to your steering wheel. Your done.
How about some links????I got the NRG mustang hub, NRG quick release v2.5 and an NRG wheel at SEMA. I'm about to go to a Personal or Nardi wheel soon though.
but what about the fr500 steering wheels? They sell a FR500s and FR500C wheel. One says its 6 bolt and one 3 bolt. Whats the deal? Do either of these require a hub adapter? Can they even be used? I love the suede.
http://rehagenracingproducts.com/product.sc?productId=1713&categoryId=73
seemed pretty technical to me...you have lost all perspective...
