Roush fun
Looking to free up some weight and space up front. Has anyone put one in there mustang and if so how much power cable was needed. I figured 15ft would be safe?!?!
Thanks
Thanks
Just installed one on mine and used the Moroso sealed box with the jegs wiring kit. 15' power and 3' ground. Only needed 14' or so
I love your set up. I'm wondering where to put everything as I want to do a battery relocation, am about to add a bottle, and I want to do an air lift system next year. Plus I have a vert and the shaker 1000 subs too. I like how you've got your trunk set up.
That's beautiful Crown!!
Crown, thanks for the pic of the disconnect, I've been racking my brain as to where I was going to install mine. I'm going to copy you.
QuickCar Part number MDS10
The insulator inside the bumper cover also needs to be trimmed a little but no big deal at all. I cut a small hole out to get the cable thru to the trunk. Just make sure to use a large grommet and something to keep the grommet from coming off like some gasket maker or something. Obviously you don't want the sharp sheet metal cutting thru the cables. That would potentially create a ground rendering the switch useless lol.
That's so cool
