skwerl
tree hugger
I looked at that Motive bleeder and they want $75, plus another $15 for the catch can! I think I'll go see if China Freight has something similar. It's a freaking pump up bug sprayer with an adapter cap is all.
Save your cash on the motive bleeder. Invite a friend for a beer, have him, her or shim help. Loosen the loosen bleeder, apply a smooth pump to the brake pedal all the down, tighten the bleeder release pedal pressure allow it to come all the way to the top and then repeat. I bought a $10 kit from O Rielly with a check valve and it worked perfectly.
For reference..Start at 1:40min end at 5:30min.. Best Brembo brake bleed vid I found.
http://www.youtube.com/watch?v=RsuO3MG0UXM
They face up because air floats and you're supposed to bleed out all the air. Of course you don't need to bleed them because you don't want to get brake fluid on those painted calipers.
Remember the part a few days ago when I asked you if the paint was brake fluid resistant? That wasn't important.
Cant you run a tube off the fitting into a bottle No spill
http://motiveproducts.3dcartstores.com/Domestic-Adapters_c_27.html
You might be able to make your own though if you can find a replacement master cylinder cap at a parts store.
