I understand that. With the proper scan tool that can do MODE 6 it can possibly pull a pending code to give you some direction.The CEL only flashes for a misfire event.
The issue cleared up, light is off.
Can you duplicate the issue? If so, light will likely stay on the second time.
You have a 20 year old car, any number of issues could cause a missfire.
What type of scanner? Does the scanner offer "Mode 6"Finally got a chance to check for codes. There are no codes
Again. Did it offer "Mode 6"? It gives you deeper info than a standard scanner.i used a blutooth obd through the torque app
Mode 6 is designed to help diagnose problems even beforea check engine light occurs.sorry idk what mode 6 is it does show live data with no problems
