BlackPearl
- Joined
- Nov 2, 2019
- Posts
- 1
- Reaction score
- 0
Hi guys,
09 has been sitting for a month while away on business. Battery was recharged and no issues with normal driving. However I was clutch in coming around a large corner at 50mph or so and before I let off, I notice steering locked up and the engine was off. I investigated and noticed at cruising speed, my car can't find proper idle, it will bounce between 0 and 500 rpm, sometimes dropping out completely causing a restart, until I'm under 10mph where it will sit as it should at around 750. It's reaching 60k and I have a fuel filter and new spark plugs on hand for a tune up.
It reminds me of an intake cowl popping off of the TB, where the engine will stall out, but the TB was installed with proper torque and a new gasket, plus the cowl is on quite snug, can't be pulled off by hand.
Some details:
Basic BAMA tune with all appropriate mods noted.
62mm TB (installed a week before I left, no issues after ecu calibrated afr after new tune and ~50mi driven. also most recent mod)
JLT cai with still fairly new filter.
I have more specifics if needed, thanks!!
Some details:
