NastyStang113
Made in U.S.A.
So my buddies car is sitting in my driveway because it won't start. It's a 2007 Mustang GT. He drove it to my house and a couple hours later it won't start. It just cranks, cranks and nothing. It has no fuel pressure so obviously it's something electrical or with the fuel system?
We checked every single fuse, moved around a few relays for the fuel pump, etc. We found a broken COP connector and bought a new one. Even knowing that wasn't the issue. We cleaned the crankshaft position sensor connection worrying that maybe it was the issue. We switched the fuel rail sensor and that didn't make a difference. We've checked wiring visually. We tore the trunk apart to verify nothing was wrong with the fuel pump wiring.
What are the chances the crankshaft posistion sensor is bad? Could a bad TPS cause this? Anything else? The PCM is fine because we were able to reflash the PCM with no issues. Could bad FPDMs cause this issue? All accessories work fine. Next thing we're doing is taking a volt meter to anything and everything.
