Clutch and pressure plate
Discussion in 'Mustang Chit Chat' started by falconsprint, Jan 15, 2020.
  1. falconsprint
    falconsprint Junior Member
    Instead of browsing the web trying to research to get a decent clutch and pressure for my 2005 Mustang GT 4.6L, 5 speed of course.
    Don't think i will race it, but punish it on occasion.
    Could i please ask your advice on a good performance setup.
    Any and all remarks would be appreciated.
    Thank you
    Jerome
  2. stkjock
    stkjock ---- Madmin ---- Staff Member Administrator Super Moderator S197 Team Member
    37,839
    823
    Stock power?
    falconsprint likes this.
  3. falconsprint
    Yea, just a tune and good muffler!
  4. stkjock
    37,839
    823
    Mcloud RST or Spec stage 1
  5. stkjock
    37,839
    823
    More than u need at present, but a deal, RXT offered in the classifiedS
  6. 86GT351
    86GT351 forum member
    4,246
    130
    Definitely more than you need but do it once.
  7. 1950StangJump$
    1950StangJump$ forum member
    649
    55
    Even an RST is more than he needs with the stock(ish) HP of about 320.
    I have the RST, and it is rated to 800HP (crank). Feel is great, but I wouldn't recommend putting up with a dual clutch's noise for 300ish HP.
  8. Juice
    Juice forum member
    610
    72
    After more than 20k driven, I am 100% happy with the Centerfoce Dual Friction clutch. Pedal feel is stock. Dorman slave/TOB also fine.
  9. Racer47
    Racer47 Doesn't have much to say S197 Team Member
    710
    59
    Exedy Mach 400 is a great choice for stock power
  10. Dino Dino Bambino
    Dino Dino Bambino I have a red car
    56
    815
    112
    I have the McLeod RXT with billet steel flywheel. Yes it's overkill but who cares? I'm not complaining. :D
  11. falconsprint
    Thank you all.
    I really appreciate you taking time to respond.
    I will evaluate you recommendations and choose.
    Thank you!
  12. Norm Peterson
    Norm Peterson corner barstool sitter
    72
    3,016
    95
    Seems like this thread describes what I might need in the way of a clutch. Stockish power (FRPP cold air & tune and an X-pipe only) with no plans to increase it. Street driving and HPDE road course running, no drag racing.
    I'm definitely interested in the Dual Friction myself, looking ahead to a possible Magnum XL swap. Pretty sure I need at least different a different spline count on the disc just to make the swap happen at all.
    I'll be running 3.73's and almost certainly a 2.66 low version of the Tremec, making 1st gear a bit taller overall than I suspect is commonly used by most people here. So I think to cover the dual-duty requirement I want to either retain the OE flywheel or go with something that's at least close to OE flywheel weight.
    I've used a McLeod before on another car, but I think there's something about their 4.6L offerings to that requires you to use their flywheel as well.
    FWIW, I had a CF/DF setup in a '79 Malibu - a 10.4" unit behind an EFI'd 350 that was entirely sufficient up to and including occasional trailer towing. Tremec transmission there as well, so 26 splines up from 10.
    Norm
  13. 07gts197
    07gts197 forum member
    836
    32
    I don’t recommend Exedy as I and a few other members have had issues with shifting and we all have Exedy clutches.
  14. Juice
    Juice forum member
    610
    72
    The dual friction 26 spline Centerforce is the direct OEM fittment to use with the tremec magnum. I am running the ford racing billet flywheel, the 20lb one. The stock 8 bolt flywheel is 28 lbs I believe.
  15. Anti
    Anti forum member
    256
    40
    I have the Exedy mach 500 and only time I have shift issues is when I fail to push clutch all the way down at the right time when speed shifting (just referring to me, no hidden meaning). I also have BMR motor mounts which removed 85% of all drive train slop believe it or not which helped with miss shifts also.. Shifts got better with that immediately. I am also using the lightened Excedy flywheel. (https://www.americanmuscle.com/exedy-race-flywheel-9604-6bolt.html#open_box) Rev matching is much more fun with that in conjunction with my lito tune for other mods.
  16. 07gts197
    836
    32
    I have a mach 350 and have had many issues. Like I said I’m not the only one with issues. I also have poly motor mounts and a steeda tri ax shifter. All the shifters I’ve ran didn’t cure the issue so I know its not the motor mounts or shifter.
  17. Anti
    Anti forum member
    256
    40
    To be clear, I am not saying your experience is invalid.
  18. 07gts197
    836
    32
    I understand, maybe its just the mach 350 and 400 that have issues.
  19. Norm Peterson
    72
    3,016
    95
    Thanks.
    I'll have to double-check whether my 4.6L uses the 6 bolt or the 8 bolt flywheel. I think I'd be OK at 25 lbs and that gearing, but I think 20 lbs would probably be a little too light for daily driving around town with 3.73 in the axle and a 2.66 1st for gearing.
    Norm
