What psi should i see roughly in each cylinder to determine all is ok? 200,160,180? What is the low end of exceptable psi in each cylinder?What % of difference between the cylinders is ok,10% 20%??
Any info would be appreciated.
Also should the compression test be done wet or dry & what do the results mean?
