13Yote
Hello,
I recently completed the oil pump gear install on my gen 1 coyote and in the process busted the oil dipstick tube. I ordered another one and when I got it, it was about and inch or so shorter than the original, and it wasnt bent like the old (likely original) one. I cross checked the part number on the package and it comes to a 11-14 coyote dipstick so I assumed it to be right.
So installed the tube into the valve cover and then the valve cover into the engine. Everything seemingly went together well, but when I push my dipstick in it hits something about 2 inches from seating all the way. Granted I can push past this rather easily and the dipstick will then fully seat normally. It reads about halfway on the dipstick which is normal if not a little lower than normal.
Has anyone experienced this? I assume the shorter and not bent new tube isnt guiding the dipstick around something (the windage tray?) that the old one did? Did I install it wrong? The shop manual is VERY unhelpful in this matter.
Thanks in advance!
Thanks in advance!
