F150 EcoBoost V6 manifolds?
good point
Twin 3071s would be WAY to much... but I like where your heads at. A single 35r would probably be pretty good fit for a 4 liter.
Completely wrong.
Borg-Warner is not low end. They make OEM turbochargers for Audi, BMW, and others. If a turbocharger is designed for OEM use, it will last longer than junk made by a lot of aftermarket companies. Take a look at the Borg-Warner EFR turbo and then tell me it's low-end.
Hell, Cosworth uses them in their racing engines. Low end my butt.
Here, do some reading and edumacate yourself:
http://www.motoiq.com/partners/borg_warner_turbo_systems.aspx
http://www.motoiq.com/magazine_arti...id/1750/borgwarner-efr-turbo-feature-set.aspx
they are good for factory and maybe longevity, but they just dont make as much power or trq per pound of boost.
yea i know a measure of resistance. i meant same turbo kit and same motor, just swap turbos.
WTF? Psi is strictly a unit of measure...
First, BW turbos are AWESOME. Their extended tip NON BB turbos are competing against others manufacturers billet compressors with BB housings and doing VERY WELL. The new turbo from them is a game changer for sure. For those not in the know, too bad for you.
Secondly, PSI is only half the equation, the other part is CFM. Two identical engines with only differently sized turbos WILL make different HP at the same PSI. Reason being is that a bigger turbo will be flowing more CFM at that same PSI than the smaller turbo. More CFM is more power.
Volumetric efficiency is also thrown into the mix.
