First off, not sure if this is actually tech. If it isn't mods please move to where ever you think it really belongs with apologizes for posting in the wrong sub-forum.
DOB, I've had a thought and wondering your thoughts on my thought. Because of your boost experience and your no BS info (props on that) on your website, I'd trust your insight.
When the Coyote came out, rod strength became a minor concern virtually overnight. As you have said it was now a fuel/knock issue. Since street boost with street gas is on the verge of popping 2V and 3V engines, would an otherwise stock 2V/3V engine with Coyote rods stand a better chance at surviving? I mean there are absolutely ridiculous numbers of 4.6 2V/3V engine cores across America. And the buy in is notably less.
Example, a dude takes a totally stock 260hp PI headed 4.6 2V in all it's 260hp glory (or a 4.6 3V) and pulls the engine. Assume the bores are within spec and just get honed and re-ringed. The crank is also within spec and so will be reused. in other words, owner reuses the crank and pistons but puts Coyote rods in it. Of course it gets balanced. For a rebuild with the added cost of a set of Coyote rods and a balance job would this engine now be real world, real pump gas safe for up to around 600 hp at the crank? I'm thinking this could be a budget path to a 600 hp rotating assembly with reliability. If tuned properly and responsibly.
