Wintermist
- Joined
- Aug 26, 2009
- Posts
- 6
- Reaction score
- 0
Heh if I tap the gas mine will shoot to 18+ (Peg the gauge) then down to 12, almost seems too sensitive got an innovate too.
Why buy that when u can buy this?
http://www.summitracing.com/parts/INN-3795/
I have the same setup in my car and compared it to a AFM-1000 and it was within .01-.02 accurate.
Same price, but thousand time better setup. Have a look at the wideband shootout in the previous post.
-Matt
-Matt
I wonder about mine too, but I have a innovate lc-1 but my gauge bounces all over the place.
Thanks Matt, I did look at it, but since it was model XD-16, I thought there was some major difference with this 229 wideband for the extra $100.
I started playing with the gauge again today. The dsp setting for the Bar Graph Display allows you to set a HI (Lean) and LO (Rich) setting for the display. This way the bar graph lights up when that setting is exceeded. Mine goes as low as 10.0 and as high as 20.0.
My AFR should be around 11.8 so I set the LO (Rich) to 11.0 and would like to set the HI (Lean) to 11.9, however, the HI setting only goes to 15.0. I don't get it.
Also went WOT in 4th today and it pegged at 10.1. Could it be a faulty sensor?
Also, can I datalog the AFR with the X3 using that wideband from Innovate you recommend Matt ? Or which one should I use
Mine did the same thing when the sensor went bad, it started showing rich erratically.
The best thing to do is a free air calibration on the sensor, and force it to re-learn the heater timing. Make the LC-1/LM-1 treat it as a new sensor in other words.
If the sensor is determined bad, the purchase a new one from autozone, they come with a 1 year warranty, so if the sensor does go bad in that 1 year then they will replace it for no charge ^_^
The settings for the delay time is located in the LM-Programer software. Just be sure that your hardware has the latest firmware on it. When i get back home ill take a screen shot of the settings box.
-Matt
Are you talking about the same gauge? Autometer Cobalt Digitial Wideband? I didn't thing these could be calibrated.
I think he is confused and thinks you have the innovate.
Before you make a buying decision based on that magazine article read this:
http://www.modularfords.com/forums/showpost.php?p=1225791&postcount=84
