DOB water pump relay
Discussion in 'Department Of Boost' started by 05sonicblue, Nov 28, 2016.
  1. 05sonicblue
    05sonicblue forum member
    155
    Hey Jason, how many pins and guage of wire on that relay?
    Thanks,
    Don
  2. Department Of Boost
    Department Of Boost Alpha Geek
    8,785
    There are 5 pins but you only use four. I used to run them with 10-12ga wire but after I did all the water pump testing I found out how little amperage the pumps really use. It's about 3A. So I started using 16ga. Hell, 18ga would even be fine.
  3. 05sonicblue
    155
    Excellent! I'm putting mine together! Just need Iw 10% od 8 rib and a few other things. I'm going to have more questions.
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    By continuing to use this site, you are consenting to our use of cookies.
