i have this car that's showing a symptom i've not seen before on the S197 platform..
a constant repetitive knock from the rear end/driveshaft (certainly not the transmission/clutch/engine) and only on deceleration, and it's certainly not the vibration noise that you get with an out of alignment driveshaft, or a bad pinion angle setting... it's a distinctive clunking noise that comes from around the rear end of the car, and i can't seem to put my finger on it just yet.
i checked all the obvious, and checked the pinion angle with poly/poly LCAs and poly/poly adjustable UCA, the angle is at -2.5 at the moment (adjusting it anywhere from 0 to -4* didn't make a difference with the noise)
i'm starting to wonder if it's the driveshaft carrier bearing, or something else in the rear end.. it's kinda hard to tell as you don't get the noise with the car free wheeling (even with the suspension loaded up on a jack), i guess the driveline needs to flex like when it's on the road to induce the symptoms, which makes it really hard to pinpoint the exact source while looking under it :S
any ideas?
any ideas?
