mike from the rock
Hi folks,
Recently ran into some electrical issues with my V6 convertible. With almost 300K kms the brake warning light came on along with a tire pressure monitoring fault and the radio and convertible top would not work. This problem would come and go so after some searching the issue I had a look at the smart junction box in the passenger side kick panel. Found a corroded pin connector and thought I had the problem solved. Bypassed the pin connector and sure enough the problem seemed to be fixed. However, after a short while it returned. This time the dash light brake warning and tire pressure fault would appear, but then switch to brake warning light, traction control on, traction control off, and a message to have my advancetrac serviced. There was nothing wrong with the brakes or trac control. Eventually the brake warning light and the tire pressure monitor light stayed on all the time and the daytime dash lights, radio and top don't work. Any suggestions on what could be the issue would be helpful. I'm leaning toward a bad smart junction box as the problem used to go away for awhile when I was working around that.
