Engine Code P0745
Discussion in '2005+ Mustang GT 4.6L Tech' started by Lee's05GT, Jun 2, 2011.
  1. Lee's05GT
    Lee's05GT Formally Qksixx S197 Team Member
    2,345
    Well my check engine light came on, I looked the code up and it says its something to do with the Pressure Control Solenoid A, when It came on I had the O/D light flashing as well then it stopped. Im not really sure what all is going to go into fixing the problem. Im going to clear the code and see if it comes back or not. Anybody ever have this code come up? BTW trans is an auto.
    Found something here http://www.sctflash.com/PDF/3000-3015 small.pdf page 5 under DTC Says, Pressure control solenoid malfunction.
  2. Doug M
    Doug M Fast Cars & Freedom
    14,574
    ^^Mine did about the same thing, o.d. light would blink and would not shift into od. and second gear band was broken, $1650.00 was my cost.
  3. Lee's05GT
    2,345
    holyyyy shit lmao. Id be better off just finding a used tranny, if thats my case. When you drove it could you tell a difference? Because when im driving mine everything feels fine, shifts fine everything.
  4. Doug M
    14,574
    ^^Just started hesitating going into the next gear, so I thought it would not be long before it would stop shifting. when its your daily driver you can't take as many chances as you normally would, oh and I just thought it was the sylenoid, they tore it down and then said it was the bands as well, you never know!!
  5. Lee's05GT
    2,345
    Yeah that is true, well mine is shifting fine I cleared the code just now so we will see if it comes back, if it does ill just buy a low mileage 5r55 for now until I go fully built
    Sent from my ADR6300 using Tapatalk
  6. Doug M
    14,574
    yea thats a good route to go, I cleared mine as well to start with, but came back on shortly after I read the codes of a bad sylenoid, then I knew it was over. ha ha.Good luck.
  7. tmcolegr
    tmcolegr It's All About the Build
    3,263
    16
    The 7G391 solenoid body assemblies were known to have issues on 2002-2005 T-Birds and 2005 Mustangs equipped with 5R55S transmissions. In April 2007 there was even a Customer Satisfaction Program 07N08 for vehicles registered in CA, MA, ME, NY & VT that covered this part under the emission warranty out to 3 months / 50,000 miles.
    A revised part# was released several years ago.
  8. Lee's05GT
    2,345
    Interesting, well I hope it doesn't come back up. If so ill be looking for a new transmission
  9. tmcolegr
    3,263
    16
    Chance are it will. I had to replace the solenoid body assembly in my 05 @ 8,000 miles. Vehicle was over 36 months, so I got the privilege of paying for the part and doing the install myself.
  10. Lee's05GT
    2,345
    How much would you think something like that would cost to do?
  11. tmcolegr
    3,263
    16
    about a 2 hour job on a lift, plus parts. Probably would be a good time to change the fluid & filter since the majority of the fluid is already drained.
    The concern I would have is the solenoid body assembly is a known issue. If/when it fails, if caught in time the transmission may not have suffered internal damage. Continue to drive it and it will lead to a major failure.
  12. Lee's05GT
    2,345
    Where can I buy the part that I need besides Ford, or is that the only place
  13. tmcolegr
    3,263
    16
    I purchased mine from Ford to make sure I had the latest/greatest part that was available
  14. Lee's05GT
    2,345
    So what do I need to ask for when I go in? People at Ford here are retarded
  15. tmcolegr
    3,263
    16
  16. Lee's05GT
    2,345
    Sweet thanks man!
  17. tmcolegr
    3,263
    16
    No problem
    I hope this cures your problem and your transmission has not already suffered an internal failure. Mine did, but that's another thread
  18. Lee's05GT
    2,345
    I hope not its been on for a few days, what do I need to look for as far as damage goes anything in particular
  19. tmcolegr
    3,263
    16
    burnt smelling/looking fluid and/or debris in the filter or pan. Even if there is no indication of a failure, that does not mean there hasn't already been damage done to the clutch discs or bands.
  20. Doug M
    14,574
    ^^True, mine hit one day and a couple days later i was getting it fixed, bands were already shot!!^^^Thanks for all your help on the trans problems, I wished i had a stick car for sure..
